Re: Re: muffler for a 1020 mc/deering
Posted by David Saville on June 05, 2000 at 18:23:52 from (142.165.111.42):
In Reply to: Re: muffler for a 1020 mc/deering posted by trudge on June 04, 2000 at 16:04:26:
Yes there was a muffler as orginal equipment. They were removed as part of the jobber carb setup which almost everybody did. There is a serial number break at #69613. Both the early and late versions also had a California and export separate part which "may be" just a spark arrester. If you can come up with the cast iron casing there was another part number for the baffle pipe inside so you could manufacture that part. There was also a sheetmetal cover for it. I have a 15-30 with the original stuff so I could measure the cover for you if it is the same. If you want it contact me.
Post A Followup
: Re: Re: Re: muffler for a 1020 mc/deering
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
