Posted by D Slater on July 17, 2010 at 17:53:07 from (72.65.148.95):
In Reply to: Starter issue posted by SCOTT300IOWA on July 17, 2010 at 15:42:36:
When the switch is turned to the start position check to be sure power is getting to the small wire terminal at the selonoid. If so its probably a bad selonoid. If not check the terminal at the switch that energizes the selonoid. If no power there its a bad switch. If power there its a problem with the wire from ignition switch to the selonoid. Or try a jumper wire from the battery cable side of the seloniod to the small terminal. (Don't know if thats how you're jumping it or across the 2 big terminals) If it turns the problem is the ignition switch or wireing. Not uncommon for those key switches to go bad.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
