Re: w4 stuck engine
Posted by caseman-d on July 17, 2010 at 20:51:09 from (75.221.139.55):
In Reply to: w4 stuck engine posted by black on July 17, 2010 at 17:44:23:
Since it was stored inside it is probably stuck from consendation. Before pulling the head drain the oil and put the plug back in, fill the cylinders full till it runs out of the spark plug hole. For better prying remove the starter and try turning the flywheel with a big bar both directions.Check the plug and oil pan and see which cylinders had drained out.Another way to pry is to raise rear wheel off ground and rock it when ever you walk by. ATF and alcohol mixture works good.
caseman-d
