Re: Running on Only 3 Cylinders
Posted by Janicholson on July 18, 2010 at 08:52:09 from (67.72.98.45):
In Reply to: Running on Only 3 Cylinders posted by 1949 Farmall MD on July 17, 2010 at 18:05:06:
Do a compression check on the gas side. It will have ~80psi or so. if one is Zero, it will require taking it apart at the valve cover on down till the issue is resolved. I like the other answers, but this test keeps you from diving into an empty pool, Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
