Posted by The tractor vet on July 18, 2010 at 09:04:57 from (76.212.231.173):
In Reply to: w4 stuck engine posted by black on July 17, 2010 at 17:44:23:
Being the type of person that i am if it had not come loose the first day the head would have been off and the pan layen on the ground already . More then likely ya got two stuck with two almost at the top and two at the bottom of the stroke and you will not get much help from tryen to turn the crank . SOOOOoooooo if ya want to try and save as much as you can i myself would take a cylinder hone to the rusted sleeves and give it a light hone job to get the surface rust off the walls then clean up as well as you can Then take some ZEP penetrating fluid if you can find it or if not then i guess ya can use PB blasters then take a good piece of oak and a small hammer like 4-10 lbs range and give them a couple good solid hits and see if it will move . Learned the hard was that getting a pry bar on a flywheel tooh makes for some interesting word when ya bust a couple teeth off it Then ya get to lean how to split a tractor to REPLACE WHAT YA broke . The way i do it will give ya a heads up on what the inside looks like and then you can decide what is needed to make it all well , do i just need a set of rings and some clean up or do i need to sleeve her and rebuild her , well since i have the head off already i might just as well do a valve job and be done with that too. When it is all done and she fires for the first time and it runs like the day she was new ya forget about all the hard work ya put into it and if well taken care of you can pass it on to the kids .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
