Re: liner removal tool
Posted by El Toro on July 18, 2010 at 16:17:53 from (74.103.74.58):
In Reply to: liner removal tool posted by Truckingthumbtack on July 18, 2010 at 12:48:15:
third party image
Here's Keith's sleeve puller. You will need to measure the sleeve bore since it could be 3.00" or 3.125" then have the puck undercut .020" to clear the bore. You can drive out those sleeves with a piece of oak and big hammer since they're wet sleeve's and are not pressed in. Hal
PS: Once you have the sleeves out you need to clean that block area below where the old seals were installed,
