You can use the I-H ONE THATS USED ON LATER MODELS H,M,SC,SA,and up. Abeline Tractor parts are the supp;iers. Used to get them from Howard Enterprise but now i have to go thru Abeline. Just got a set Sleeves,rings, pistone,rod and main bearings and gasket out of frame for 374 delivered to my door UPS 3.125 set. I do believe they have the tallest dome on the market. No need to go 12v just use 1ga cables a 725 batt and re-do the starter new brushes and maybe bearings. It will start and run without going12v.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
