Posted by Janicholson on July 18, 2010 at 21:24:42 from (67.72.98.45):
In Reply to: M tubeless tires? posted by MeanGene1 on July 18, 2010 at 20:01:34:
Tubeless tire rims are different than conventional tube rims. The bead on a tubeless tire is designed to be seated on a tapered section of rim such that when it is against the rim wall it is also pressing hard against its inner diameter om the rim. This is not true of conventional tube type rims, they are basically flat at the bead till the flange. THe tubeless tire engineering specification and rim is very different. You could put a tube in the tire, (being sure that it is the correct size) and possibly have that work. But it will not work as a tubeless on a standard rim, even with a sealing goo, it will not seat correctly, and will deflate radically. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
