Re: Super A rear axle leaking
Posted by okierob on July 18, 2010 at 21:34:18 from (65.67.203.193):
In Reply to: Super A rear axle leaking posted by MontyC on July 18, 2010 at 12:47:42:
check the transmission oil level and make sure it isnt full of water makeing the oil level too high.
other then that it is'nt too bad of a job if you can handle the weight of the final drive. it is pretty heavy once it is loose.
think safety and make sure it is blocked properly.
