Re: H battery discharging
Posted by Shawn in PA on July 16, 2010 at 19:42:59 from (24.154.38.87):
In Reply to: H battery discharging posted by Drewbee90 on July 16, 2010 at 17:42:50:
Did you convert to 12 Volt? With a test light, hook one end to the negative battery post, the other end to the negative battery cable you just disconnected. Leave the positive cable hooked to the battery. The test light will glow if there is a drain. Then it's just a matter of finding where the draw is coming from.
