Re: Starter button infopic's
Posted by rustyfarmall on July 19, 2010 at 07:36:16 from (209.152.78.140):
In Reply to: Starter button infopic's posted by mkirsch on July 19, 2010 at 05:45:31:
mkirsch said: (quoted from post at 05:45:31 07/19/10) Why do you think they went to solenoids on later tractors?
It's because those starter buttons were never the right tool for the job. They have ALWAYS been a problem, right from the get-go.
The problem is, you can't push the starter button fast enough to make contact without a spark jumping across the gap. Eventually, the sparks burn the contacts, and the switch stops working.
If you got 5 years of regular use out of a starter switch, then you've done well.
I've got a 1950 H with what appears to be the original starter button. I've owned this tractor for 12 years, it sees regular use because it is a working tractor, and the starter button works just fine. I've never had a speck of trouble with it.
