Re: Farmall H Starter!!!
Posted by jason the red on July 19, 2010 at 09:30:04 from (99.109.179.225):
In Reply to: Re: Farmall H Starter!!! posted by Justin M on July 17, 2010 at 18:57:56:
You stated you may have a fuel issue also. You may try to start by fixing that. If the engine isn't getting the fuel it needs to start, it doesn't help things. A six volt system typically doesn't spin the starter overly fast anyway, so it may be spinning fast enough to start with a good well charged battery, and proper sized cables (00 gauge) but with all the other problems you have you're just draining the battery causing some of your starter problem. If it were mine, I would fix the fuel problem, then work on the charging system, and worry about the starter last. Hope this helps.
