Re: Farmall H Starter!!!
Posted by Owen Aaland on July 19, 2010 at 15:36:36 from (207.13.114.172):
In Reply to: Farmall H Starter!!! posted by hoopy on July 17, 2010 at 14:58:21:
Justin M said: (quoted from post at 18:06:07 07/18/10)
Well here is another thing I left out.I am so lost with this right now, I keep leaving things out to tell yall. I did take the starter to get rebuilt, and he said it was in good shape, but needed a couple things. Well it came back and did the same thing as it did before, barely anything. So I have a feeling he didnt look at that.
If the solder joint was only cracked and the stud had not turned yet, it is possible that the starter spun pretty well with no load on it.
Once you have worked on a few of those starters you learn to look very closely at that stud for a cracked joint.
