Re: Farmall M rear main oil seal
Posted by Nebraska Kirk on July 19, 2010 at 20:51:28 from (207.91.4.141):
In Reply to: Farmall M rear main oil seal posted by rustieiron on July 19, 2010 at 20:41:55:
You will have to split the tractor to replace the rear main seal. If you can make or borrow a splitting stand, then you can unbolt the engine from the clutch housing and then roll the whole front half of the tractor ahead enough to remove the clutch and flywheel. Then you can unbolt the seal retainer and replace the felt seal.
