Posted by d. coleman on July 20, 2010 at 03:41:46 from (12.166.210.183):
In Reply to: Cub oil leak posted by Mike in Ohio on July 19, 2010 at 21:00:47:
oil pump is bolted to rear of camshaft behind flywheel. if gasket is leaking dont make one any thicker than original. the extra clearance will cause oil to go between pump gears and housing, causing a loss in oil pressure. the cub i just o/h was seeping at pump gasket (bolts slightly loose) so i drilled the bolt heads and safetied them with wire. good luck, d.coleman
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
