Re: Distributor problems
Posted by El Toro on July 20, 2010 at 06:12:48 from (74.103.74.58):
In Reply to: Distributor problems posted by Marv on July 20, 2010 at 05:41:31:
Make sure your wires are not touching a ground
where your coil and condenser wires are connected at the points. Clean your new points with a q-tip dipped in alcohol. Hal
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
