As Jim says the connector bolt that goes through the distributor housing needs to be insulated. There is a fiber washer with a raised ridge around its center hole that is intended to keep the bolt centered in the distributor hole. The first nut on the outside of the distributor that goes on the bolt is to keep the fiber washer in place and needs to be tight at all times. The second nut holds your electrical wire. Always hold the lower nut in place as you tighten or remove the top nut.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
