Posted by Janicholson on July 20, 2010 at 07:11:32 from (199.17.55.140):
In Reply to: Strange M question posted by GaryinKS on July 19, 2010 at 19:48:04:
An idler gear (three gears) between the cam and crank, maintaining the 2:1 ratio, (or a chain drive) will do the main tasks. No cam or distributor or oil pump problems will happen. The Pistons .could be reversed (I do not know if they have thrust side offset, they may not, so no issue there. The gear change just reverses the rotation of the crank, nothing else changes. Timing the ignition will be your responsibility,but TDC is TDC. Starter motors with reverse spin can be rewired, or a starter from a Power unit (front mount) spins opposite. Jim thinking out loud
