Re: Rough running A
Posted by El Toro on July 20, 2010 at 07:59:55 from (74.103.74.58):
In Reply to: Rough running A posted by rustin on July 20, 2010 at 07:48:29:
Sounds like the engine is starving for gas. You need to check the gas flow from the tank to the carburetor. If there's just a trickle you have blockage in the tank or the gas line. If there's a full stream of gas from the gas line you need to remove that fitting from the carburetor and look for a clogged screen. If that screen is clean your carburetor probably needs a good soaking in carb cleaner and all jets blown out with air pressure. Check the float height to make sure it's set high enough.
Hal
