Re: H Distributor Shaft Removal?
Posted by JLE on July 20, 2010 at 12:12:03 from (173.123.114.44):
In Reply to: Re: H Distributor Shaft Removal? posted by Janicholson on July 20, 2010 at 11:41:10:
The pin is riveted in place, grind or file one or the other off till you can the out line of pin through the gear, drive out with pin punch. the the gear should come off with little problem.
Clean reassembel, use a pin to replace origeanal.
rivet in place. JLE
