The only problem with using 3pt draw bar is if you are pulling an implement where you have to do sharp corners the 3pt draw bar will limit on the tongue of the implement. Also on PTO implement must make sue 3pt lever can not be raised will draw bar is installed. Also if no down pressure on 3pt draw bar must be lower than the mid point 3pt lift height or 3pt will go up when being pushed down a hill by a wagon. Older Fergusons had sway bars plus bars that went to top link pin that held 3pt draw bar solid.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
