Re: Using 3pt As Draw Bar
Posted by Joe Pennington on July 20, 2010 at 14:26:26 from (68.51.24.219):
In Reply to: Using 3pt As Draw Bar posted by ewalker on July 20, 2010 at 08:42:22:
Consider installing the original swinging drawbar for an H which hooks up under the tractor's belly and then attach it at the back to the existing cross member of your three point hitch with a strap underneath attached with two heavy bolts. If you shorten the now non-swinging drawbar by 3 to 4 inches you will find it about the right length for drawn implements. Might be necessary to beef up the cross member a little so it can support a little more tongue weight.
