Re: Cub oil leak
Posted by gene on July 20, 2010 at 16:03:16 from (66.43.40.73):
In Reply to: Cub oil leak posted by Mike in Ohio on July 19, 2010 at 21:00:47:
Not the oil pump leaking. If it were it would lose it's prime.
Rear main engine seal or transmission front seal. Both oil leaks show up at the same location.
If you haven't done so, drain the transmission/differential and refill. Transmission has a tendency to accumulate water bringing the oil level up to and on the seal.
