Re: Found A Whatzit, Sorry no picture...
Posted by Owen Aaland on July 20, 2010 at 20:09:21 from (207.13.114.172):
In Reply to: Found A Whatzit, Sorry no picture... posted by Crazy Red Power in SE-WI on July 20, 2010 at 09:50:24:
Are you adding IH valves to your 400? If you go with six valves you may have to enlarge the orifice hole size in the screen to get the system to stay off of high pressure. The orifice has to be able to pass more oil through than leaks past the spools when the valve are in neutral to be able to move the unloader valve to standby pressure.
