Re: Farmall M head
Posted by randy hall on July 21, 2010 at 15:00:02 from (209.143.0.64):
In Reply to: Farmall M head posted by Bob D 42 on July 21, 2010 at 13:23:30:
like rusty said the combustion chamber is a lot deeper and that makes the valves shorter. there is quite a difference in power. m+w made pistons with a inch tall dome to raise the compression on a low compression engine. useing a distillate head will turn your m into an h for power.
