Posted by NDS on July 22, 2010 at 11:44:56 from (72.146.39.198):
In Reply to: Re: 1086 IH weight posted by rustyfarmall on July 22, 2010 at 07:20:50:
Rusty I am curious as to why you think a tractor with 12000 lb. official shipping weight (bare tractor) will load 14000 lb. GVWR trailer that probaly weigh 3000/4000 empty to twice its capacity. I have seen lots of similar rigs cross scales and be given green light without hesitation.
On interstate system weights are set by Federal regulations and 23 CFR 658.17 (f) says.....Except as provided herein, States may not enforce on the Interstate System weight limits of less 20,000 lbs. on single axle, 34000 lbs. om a tandem axle, or the weights derived from the bridge formula, up to a maximum of 80,000 lbs., including all enforcement tolerances. States may not limit tire loads to less than 500 lbs. per inch of tire tread width, except that that such limits may not be applied to tires on the steering axle. States may not limit steering axle weight to less than 20,000 lbs. or the axle rating established by the manufacturer, whichever is less. For complete Federal Weight limits do Google search for "23 CFR 658.17".
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
