On my 100 spreader, I ground the ends off the rivets and then used a punch to drive them out. With a good 4 inch angle grinder, it only takes a few seconds to grind off each rivet so it can be driven out. As to the rotted floor and the rivets there, I used an angle grinder with a thin cutting wheel to cut them and then drive out. A reciprocating saw would work too I think. When you go to cut new boards for the floor, be aware that the body of the spreader is wider at the rear by about 1 inch and the edge boards need to be tapered to compensate for that. The body is wider at the rear so the manure can be easily pushed to the rear by the drag chains. I replaced the floor and the metal sides in my 100 spreader.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
