Posted by rustyfarmall on July 22, 2010 at 13:37:17 from (209.152.78.140):
In Reply to: Carb upgrade? posted by nosoup4u on July 22, 2010 at 13:01:05:
nosoup4u said: (quoted from post at 13:01:05 07/22/10) The most common I guess would be flooding and running rich.
It ran and started great for a couple of months, and then suddenly one day while mowing it started coughing black smoke and acting like it wants to die. Ever since then it has been hard to start and run poorly.
I will guess that a speck of rust or other crud has found its way to the needle valve and is preventing it from closing fully. You need to make sure that the fuel inlet fitting on the carb still has the fine mesh, internal screen in place, and that your sediment bowl also has the filtering screen in place.
You should be able to take the carb apart, remove the needle valve, clean it good, and put it right back in.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
