Posted by Fixerupper on July 22, 2010 at 17:53:43 from (207.199.205.40):
In Reply to: Carb upgrade? posted by nosoup4u on July 22, 2010 at 12:11:57:
Is there an accelerator pump in this carb? If it does there's a chance it's sucking gas past the pump plunger. I'm not an expert on this by any means, but I did have a problem like this on my 105 gas combine with a 4020 engine. Deere had an accelerator pump in the Marvel Schebler carb on some of the new generation models, and when the brass vacuum piston wore a little in the bore gas would start sucking around the piston and into the intake manifold. I plugged the vacuum hole in the top of the carb and that stopped the rich idling and helped the fuel economy. The downside was I had to open the throttle slowly or it'd cough and spit. I was told the Oliver 1850 gas had the same carb and the same problem too. Just an off-the-cuff suggestion. Jim
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
