Mike, my reply wasn't meant to be "smart" as you put it. Fact is, that as John M said, the fast hitch system is so simple to switch from implement to implement, or drawbar as the case may be that the only thng simplier is to have a second tractor hooked to what you whatever .
I farmed with fasthitch equipment from the late '50s to the early '70s. It wasn't unusuall to switch fast hitch implements several times a day. It was also common practice for us to unhook whatever fast htch implement we were using at noon or quitting time & leave it in the field and just take the tractor home. The guy running a pull type implement sure didn't do that. He usually parked his tractor in the field & rode in with the other guy.
If you still consider my reply as "smart", well so be it but I still say the only thing simpler than switching fasthich equipment is having a tractor on each piece of equipment being used.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
