Re: gas or dist. head?
Posted by rustyfarmall on July 23, 2010 at 05:20:45 from (209.152.78.140):
In Reply to: gas or dist. head? posted by ks sodbuster on July 23, 2010 at 05:15:15:
ks sodbuster said: (quoted from post at 05:15:15 07/23/10) Is there a way I can tell without take off the cylinder head if I have a gas or distilite. head? Im still needing to use the tractor but I also need to put new valve guides in so Ive got to get them ordered.
Thanks
If you remove the valve cover, you will find a part number cast, not stamped, on the top of the head, towards the rear. I don't remember right now what the number might be, but someone else will know. You will probably have to scrape away some crud to find it.
