Re: Bob Ms 12 v conversion
Posted by Bob M on June 07, 2000 at 04:41:16 from (192.232.120.194):
In Reply to: Bob Ms 12 v conversion posted by Robert B on June 06, 2000 at 19:41:50:
Bob - If your tractor runs on with the ignition switch "off" and the warning light removed, either it's wired up wrong or the regulator inside the alternator is bad.
Double check your wiring and let me know what you find!
Bob M
PS - No problem using a toggle switch in the #1 wire, so long as you remember to turn it on and off. Can also use a diode (1 amp and 50 PRV or higher rated) in place of the switch.
Post A Followup
: Re: Re: Bob Ms 12 v conversion
