Re: Starter Problem Still!!
Posted by Justin M on July 23, 2010 at 16:02:10 from (66.245.86.30):
In Reply to: Starter Problem Still!! posted by d.coleman on July 23, 2010 at 14:42:05:
d.coleman said: (quoted from post at 14:42:05 07/23/10) is this the same starter the has worked satisfactrally in past? is there any chance the bendix isnt properly aligned or to tight on ring gear of flywheel? just a thought. good luck, d.coleman
The battery cables are brand new, and no, the starter has not worked since rebuild, it would turn the motor over 1 or 2 times then stop, and the 1 or 2 times was so slow. I think I am gonna buy a new starter.
