Re: Starter Problem Still!!
Posted by wayne in mn on July 23, 2010 at 18:57:56 from (68.119.26.245):
In Reply to: Starter Problem Still!! posted by Justin M on July 23, 2010 at 13:00:05:
Do you have the original style starter with the heavy switch on the steering post or newer style with the switch on the starter & a pull rod is used to activate?
If the later, check the screws that hold the switch to the starter because if they are too long they will penetrate the field coils inside the starter and sparks will fly when attempting to start the engine. BTDT!!
