Re: Super A implements
Posted by mkirsch on July 24, 2010 at 01:01:37 from (64.80.108.56):
In Reply to: Super A implements posted by mike in MB on July 23, 2010 at 19:46:41:
Your biggest issue will be the offset PTO.
With a 3pt implement, the PTO shaft will be at an angle, and may hit the framework of the implement.
On a trailing implement you can hitch it offset to the left and get the PTO shaft straight.
