Re: Starter Problem Still!!
Posted by Plane Bart on July 24, 2010 at 05:20:42 from (65.217.55.195):
In Reply to: Starter Problem Still!! posted by Justin M on July 23, 2010 at 13:00:05:
Check the stud insulator bushings where your battery cable connects to the starter if this is shorting out it will cause the same problems, could have a shorted feild in armature also.
If all else fails take it apart if it is shorting out you will find evidence of the arching somewhere inside the starter.
Good Luck.
