IPTO to the front and center
Posted by Wardner on July 24, 2010 at 19:53:06 from (4.154.238.197):
A shaft from the rear runs under the left axle and ends near the joint between the clutch housing and rear frame. Chain runs under tractor and fills that notch where the 1/4" NPT drain plug is located on the 400 and others.
The shaft and bearing pictured below is from a wobble drive IH mower. The front shaft and bearings in the second picture pierce the front Fast Hitch crossmember.
Don't ask what I am going to do with it. I just figured that if I build it, the ideas will come. I now have power out the back, both sides, and the front.
third party image
third party image
