Re: 560 diesel fuel consumption
Posted by Wardner on July 24, 2010 at 22:23:29 from (4.154.235.193):
In Reply to: Re: 560 diesel fuel consumption posted by a bartholomew on July 24, 2010 at 21:53:09:
Yes, switching to single acting will work. You can also pull the rear pin on the Fast Hitch sockets. The sockets will rotate on the pin several inches ahead and below the removable pin. I am not sure but I think the one pin pull feature is used for plowing, You will find these pins at the front of the sockets (nearest to axle). I believe the removable pin is !" dia. All big tractor fast hitches after the 300/400 used this setup.
You should get an operator's manual. It will explain all the options.
