Farmall H generator
Posted by w400 on July 25, 2010 at 03:23:05 from (195.93.21.97):
Hi Guys back at Generator again today Bob and Janicholson thanks for previous reply generator is charging but still showing 18amps on amp meter and 8.6 volts at battery is it over charging doesn't seem to cut out at all battery voltage reading 6.3 with engine switched of it as though the field is not working also generator running very hot I think can barley put you hand on it.any ideas thankyou. changed the regulator again today berfore I started polarised and all.
