Re: Re: Re: Re: Need help finding seals for Farmall H cross shafts
Posted by Harry on June 07, 2000 at 08:43:36 from (143.91.70.114):
In Reply to: Re: Re: Re: Need help finding seals for Farmall H cross shafts posted by The Red on June 07, 2000 at 08:10:49:
If I understand you correctly,
1)the new seals are not a thick as the old seals?
2) I should not "bottom" the first seal all the way inside the bull cage? ((I'm assuming that there is a flange on the bull cage that the first seal bottoms out against, and then you bottom out the second seal against the first)
3) If there is no flange in the bull cage, I should just eyeball the depth I install the first seal and then put the second seal in against it so that it just makes contact with the first seal?? Also assuming that the second seal would be flush with the outer surface of the bull cage.
Post A Followup
: Re: Re: Re: Re: Re: Need help finding seals for Farmall H cross shafts
