Re: Re: 140, rockshaft mower belt pulley?
Posted by Pete in PA on June 07, 2000 at 09:28:31 from (134.192.209.158):
In Reply to: Re: 140, rockshaft mower belt pulley? posted by Steve on June 06, 2000 at 20:49:52:
Steve,
Thanks for your response, this is *exactly* what I had in mind - using a rear rockshaft for an aftermarket 3pt hitch but didn't want to have to mess around with dropping my Woods L59 every time I wanted to use it...any tips / suggestions / things you would do differently about your setup?
thanks
Pete
Post A Followup
: Re: Re: Re: 140, rockshaft mower belt pulley?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
