Re: Woods L59 on Cub LoBoy
Posted by haas on July 25, 2010 at 14:23:21 from (75.234.235.106):
In Reply to: Re: Woods L59 on Cub LoBoy posted by muleboss on July 24, 2010 at 20:51:22:
You can't just replace the blades on a mower if you want to reverse the rotation. The threads on the spindle bolts of the L (left hand mowers) are left hand. On the R mowers the threads are right hand. this is to make the bolts tend to tighten under load and keep the bolts from unscrewing and the blades coming off. And..they will unscrew and come off if the threads are wrong!!! Anyhow, the belt setup on the cub can be arranged to accomodate either a left hand or right hand rotation mower.
