Re: 3 Gallons of Oil in Crank Case of my SA
Posted by Daniel H. on July 25, 2010 at 14:38:59 from (66.226.34.159):
In Reply to: 3 Gallons of Oil in Crank Case of my SA posted by TomA on July 25, 2010 at 10:20:43:
Be sure to check the touch-control (hydraulic fluid level, too. There is a large plug on the left side below the gas tank. Fluid should be within 1/2" of the hole. You may need a funnel with a hose to fill it. Recommend Hy-Tran fluid from a Case/IH dealer, but if not available be sure it is hy-tran compatable.
