Re: Help Indentify this Tractor.
Posted by ScottyHOMEy on July 25, 2010 at 16:15:12 from (70.105.248.6):
In Reply to: Re: Help Indentify this Tractor. posted by AL Farmall Boy on July 25, 2010 at 15:44:42:
Al, there is no place on the that tractor where a conventional starter went. It would have been at the forward "bell" end of the torque tube on the right-hand side. It is simply not there. What you have is a torque tube from the first 55,000 or so on which an electric starer was not even an option. After that time, when the starter was an option, the shape of the casting changed and it was delivered with a hole to take either a wired-up starter or a blank plate to cover the hole. Yours lacks that hole.
As far as your PTO, the one that runs perpendicular to the center line of the tractor is for a belt pulley. The tractor does not have the customary PTO on it. I'm not sure what you refer to as a tag. There would be no tag on a PTO or in the absence of one. What you have there is a cover plate (often called a "delete" plate) to cover and seal the hole where the PTO would normally have mounted. Same idea as the plate that would have covered the hole where the starter would have gone if your torque tube had been cast and machined to take one.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
