Can anyone recommend a supplier for both the upper and lower bushings and seals?
pete 23 said: (quoted from post at 14:12:18 07/22/10) I have never seen grease do a good job of lubricating the shaft below the gear and there fore wears the shaft. Put in a new bushing and seal and if shaft is good it will be good for many years. Corn head grease doesn't cut it . IH at one time had a additive that was used with engine oil in tractor transmissions before they developed hyddddd-tran fluid and that additive alone was the recommended full strength lube in all the manual steering boxes and it worked great, but they no longer have it so I use the best extreme pressure gear lube I can get my hands on.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
