Posted by Janicholson on July 25, 2010 at 19:02:10 from (67.72.98.45):
In Reply to: Cub Won't Start posted by Roger46 on July 25, 2010 at 17:57:01:
Yes A fast cranking Mag will spin so fast that the impulse coupling will not engage the housing. this results in way advanced timing, and not enough rotation of the magnet to make good spark at starting, not running speed. I would try pull starting it if you and the pulling person are solid with the protocol of pull starting a tractor. Do not if at all nervous! If it runs when pulled, the impulse system in the mag drive might need to be fixed.
If you can hear the mag coupling snapping (as it does when hand cranking) it might be something else.
Heat up the plugs with a propane torch to get them clear of shorting material. put them in warm. It helps a lot. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
