Re: fuel in oil 706D
Posted by DanD on July 26, 2010 at 09:21:16 from (156.144.250.239):
In Reply to: fuel in oil 706D posted by Michael Johns on July 26, 2010 at 08:10:02:
I don't know much, but if your 706 is like my 560, the return fitting on the tank bottom is a check valve. The ball can stick shut and the engine will die. Guys will just remove the ball and things run fine. My first thought was the opposed rubber seals on your inj pump drive shaft are leaking? This would allow fuel to go straight into your crankcase. They can be damaged during pump install. If your trouble is happening while running, it couldn't be the return line since it has to pump fuel to the tank or else she won't run.
