Re: Farmall A Governor Shaft Removal
Posted by Adrian Billheimer on July 26, 2010 at 22:10:23 from (173.86.29.199):
In Reply to: Farmall A Governor Shaft Removal posted by FM on July 26, 2010 at 19:43:11:
Mike,
I just looked in my parts book for my A, it looks like the weights have to come off, then the shaft pulls out towards the rear of the tractor.
I rebuilt the governor on mine the winter before last, but did not remove weights or shaft, just gov. housing it runs great now, can idle it down now too.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
