Re: A pto ?
Posted by Red Dave on July 27, 2010 at 07:15:15 from (66.216.141.163):
In Reply to: Re: A pto ? posted by KD Cannon on July 27, 2010 at 06:57:37:
It appears that you have a PTO. The picture is not clear on whether you also have a belt pulley. Many mowers use the belt pulley drive (with the pulley removed) to power the mower.
The belt pulley is at a right angle to the PTO, just above the PTO, kind of below the seat. That may be what you have seen on other tractors.
If you need one, I would expect that one could be obtained from a salvage yard. You would probably need the entire PTO assembly from the transmission back.
