Re: Mow Board for Cub Sickle Bar
Posted by usetabesteve on July 27, 2010 at 09:56:15 from (168.166.54.11):
In Reply to: Mow Board for Cub Sickle Bar posted by higgi on July 27, 2010 at 09:30:52:
If you get a pattern, great.
If not, none of the measurements are critical except for the end that bolts to the cutter bar. Trace that from the piece the board bolts to.
The board needs to be about two and one-half feet long, three-fourths of an inch thick, and six inches wide. It's customary for the end to be rounded. About two-thirds of the way back on the side toward the tractor a round stick is mounted angled about fifteen degrees out from the board and fifteen degrees up from horizontal to sort of fold the edge of the swath over on top of itself. The board and stick create a bare space at the edge of the standing hay for the inside edge of the sickle to run without fouling.
